Continuing in this thread as it's mainly to do with my rsyncing project.
For testing I have a small set of files locally that I can use to rsync with the empeg - about 20 mp3s and playlists - but the playlists and database files are simply the empty ones as originally created by jEmplode when there was no music at all. IOW, they do not correspond to the files that get uploaded.
After the sync the player app will not start, it just gives a lot of error messages of which this is the end:-
no room for private writable mapping
error: -12
error: -12
player(134): memory violation at pc=0x0207b864, lr=0x0203a954 (bad address=0x021
78014, code 2)
pc : [<0207b864>] lr : [<0203a954>]
sp : bfffba3c ip : bfffba60 fp : bfffba5c
r10: 2dc6cba0 r9 : 00002dc7 r8 : 00000000
r7 : 00008140 r6 : 0216fe38 r5 : 0216fe38 r4 : 00000178
r3 : 00001028 r2 : 02177fd4 r1 : 00000178 r0 : 0216fe38
Flags: Nzcv IRQs on FIQs on Mode USER_32 Segment user
Control: C0B8117D Table: C0B8117D DAC: 00000015
Function entered at [<0207b83c>] from [<0203a954>]
r6 = 00000178 r5 = 0216FE38 r4 = 02177F7C
Function entered at [<0203a868>] from [<0203aebc>]
r10 = 02175818 r9 = 02112374 r8 = 0214D808 r7 = BFFFFD88
r6 = 0214EF4C r5 = 02175808 r4 = BFFFFD80
Function entered at [<0203aea8>] from [<02061a54>]
The first line gets repeated a LOT first.
I thought that the player app would rebuild the appropriate files if there was a mismatch, why is it having such a problem here?
My intention is that the correct and matched playlist and database files will be uploaded at the same time with the music files and playlists, so this shouldn't be a problem in any case, but I want to get some idea of what's going on here.
Any suggestions as to what is the problem for the player?
