#359072 - 28/06/2013 20:20
Re: Empeg player software, a new generation
I also now took your broadcastfb_proc.c program, changed it only very slightly, to simply send the NextTrack hexcode pairs once every five seconds, and this also works:
// broadcastfb.c
// Hiijack kernel adds /proc/empeg_screen.raw file. Try reading this instead
// Verson 3.1
// Jonathan Andrews ( j o n @ j o n s h o u s e . c o . u k )
// Last Changed 28 Jun 2013
// Always seems to send 38 frames per second, I think the empeg display is refreshed faster
// but its tricky to find a way to read it without corruption.
// Version 2 adds support for remote button presses via UDP port.
// Version 3 adds support for messages in the form 0x12345678, these are key press or
// consumer IR 4 byte (long int) represented as hex.
// These messages are sent to /proc/empeg_ir to proxy infra-red sequences or just button
// push/release events
#define PORT 4040
#define RXPORT 5050
#define DEST_ADDR "255.255.255.255"
unsigned char fbdata[32*64]; // 32 Rows of 64 Bytes = 2048 Bytes (2K)
#define TRUE 1
#define FALSE 0
#include <stdio.h>
#include <sys/types.h>
#include <sys/stat.h>
#include <fcntl.h>
#include <unistd.h>
#include <sys/mman.h>
#include <sys/ioctl.h>
#include <sys/resource.h>
#include <errno.h>
// sockets related
#include <sys/socket.h>
#include <netinet/in.h>
#include <netdb.h>
int sockfd;
int rxsockfd;
int proc_buttonfd;
int proc_irfd;
#include <sched.h>
void set_realtime(void)
struct sched_param sparam;
sparam.sched_priority = sched_get_priority_max(SCHED_RR);
sched_setscheduler(0, SCHED_FIFO, &sparam);
// Received UDP packet.
unsigned char ubuffer[512];
int main(int argc, char *argv[])
struct sockaddr_in sendaddr;
struct sockaddr_in recvaddr;
int numbytes;
int broadcast=1;
int allon;
int allblack;
int limit;
int flags;
int j,i,fd;
int res;
caddr_t dmap;
int addr_len;
long ircode=0;
char st[1024];
set_realtime(); // Marking as realtime gives more FPS but some clashing with player
// nice myself to higher priority
setpriority(PRIO_PROCESS,0,-20); // Give this process a CPU boost, same nice as pulse
// Setup receiving UDP socket
if((rxsockfd = socket(PF_INET,SOCK_DGRAM,0)) == -1)
perror("rx sockfd");
exit(1);
// Setuop socket, specify listening interfaces etc
recvaddr.sin_family = AF_INET;
recvaddr.sin_port = htons(RXPORT);
recvaddr.sin_addr.s_addr = INADDR_ANY;
memset(recvaddr.sin_zero,'\0',sizeof (recvaddr.sin_zero));
// Put socket in non blcoking mode
flags = fcntl(rxsockfd, F_GETFL); // Get the sockets flags
flags |= O_NONBLOCK; // Set NONBLOCK flag
if (fcntl(rxsockfd, F_SETFL, flags) == -1) // Write flags back
perror("error,fcnctl failed - could not set socket to nonblocking");
exit(1);
if(bind(rxsockfd, (struct sockaddr*) &recvaddr, sizeof recvaddr) == -1)
perror("bind");
exit(1);
printf("Listening on UDP port %d\n",RXPORT);
fflush(stdout);
// Setup sending UDP socket
if((sockfd = socket(PF_INET,SOCK_DGRAM,0)) == -1)
perror("sockfd");
exit(1);
if((setsockopt(sockfd,SOL_SOCKET,SO_BROADCAST,&broadcast,sizeof broadcast)) == -1)
perror("setsockopt - SO_SOCKET ");
exit(1);
sendaddr.sin_family = AF_INET;
sendaddr.sin_port = htons(PORT);
sendaddr.sin_addr.s_addr = inet_addr(DEST_ADDR);
memset(sendaddr.sin_zero,'\0',sizeof(sendaddr.sin_zero));
printf("Sending packets on UDP port %d\n",PORT);
fflush(stdout);
// Open hijack kernel version of framebuffer
fd = open("/proc/empeg_screen.raw", O_RDWR);
if (fd == -1)
perror("open /proc/empeg_screen.raw failed");
// Open /proc/empeg_notify so we can push button presses into it
proc_buttonfd=open("/proc/empeg_notify",O_RDWR);
if (proc_buttonfd < 2)
perror("Failed to open /proc/empeg_notify for RDWR\n");
exit(1);
//proc_irfd=open("/proc/empeg_ir",O_WRONLY);
//if (proc_irfd < 2)
//perror("Failed to open /proc/empeg_ir\n");
//exit(1);
while (1)
if (0) {
lseek(fd,0,SEEK_SET);
read(fd,fbdata,sizeof(fbdata)); // Read data from framebuffer
numbytes = sendto(sockfd, &fbdata, sizeof(fbdata), 0, (struct sockaddr *)&sendaddr, sizeof(sendaddr));
//numbytes = sendto(sockfd, dmap, 2048, 0, (struct sockaddr *)&sendaddr, sizeof(sendaddr)); // direct from FB data
if (numbytes<=0)
perror("sendto error");
exit(1);
else
//printf("Sent %d bytes\n",numbytes);
//fflush(stdout);
// Receive text and send it to empeg player to process.
addr_len=sizeof(recvaddr);
numbytes = recvfrom (rxsockfd, (char*)ubuffer, sizeof(ubuffer)-2, 0, (struct sockaddr *) &recvaddr, &addr_len);
ubuffer[numbytes]=0; // terminate actual string
ubuffer[sizeof(ubuffer)-1]=0; // ensure buffer is always 0 terminated
} else {
sleep(5);
strcpy(ubuffer, "0x0020DF11");
numbytes = strlen(ubuffer);
if (numbytes > 0)
printf("Got %d bytes from receiving UDP socket [%s]\n",numbytes,ubuffer);
fflush(stdout);
// If message starts 0x and is 0x12345678 long then its an IR code
if ( (ubuffer[0]=='0') & (ubuffer[1]=='x') )
if (strlen(ubuffer)==10) // sequence is 0x12345678
sprintf(st,"BUTTONRAW=%s",ubuffer);
res=write(proc_buttonfd,st,strlen(st)); // write text to /proc/empeg_notify file
printf("sent %s, result %d\n",st,res);
fflush(stdout);
usleep(250000);
strcat(st,".R");
fflush(stdout);
else
write(proc_buttonfd,ubuffer,strlen(ubuffer)); // write text to /proc/empeg_notify file
usleep(5000); // works well, 38 frames/second
close(fd);
julf
02/05/2013 14:07
julf
02/05/2013 14:10
jonshouse
02/05/2013 14:35
jonshouse
02/05/2013 15:25
jonshouse
03/05/2013 01:26
jonshouse
04/05/2013 13:59
jonshouse
09/05/2013 00:01
julf
09/05/2013 06:11
jonshouse
09/05/2013 13:31
jonshouse
09/05/2013 19:28
jonshouse
09/05/2013 21:22
jonshouse
10/05/2013 16:48
jonshouse
10/05/2013 19:30
jonshouse
11/05/2013 20:05
jonshouse
12/05/2013 19:15
jonshouse
23/05/2013 13:26
Waterman981
23/05/2013 20:49
jonshouse
02/06/2013 12:21
jonshouse
08/06/2013 21:56
jbrinkerhoff
13/06/2013 14:53
jbrinkerhoff
13/06/2013 15:21
jonshouse
17/06/2013 23:47
jonshouse
19/06/2013 22:17
jbrinkerhoff
21/06/2013 15:56
jbrinkerhoff
25/06/2013 15:37
jbrinkerhoff
25/06/2013 16:00
jonshouse
25/06/2013 16:33
jbrinkerhoff
25/06/2013 23:49
jonshouse
26/06/2013 13:14
jbrinkerhoff
26/06/2013 16:28
jonshouse
26/06/2013 22:07
jonshouse
27/06/2013 13:37
jonshouse
27/06/2013 18:27
jonshouse
28/06/2013 13:32
jonshouse
28/06/2013 14:53
jonshouse
28/06/2013 14:32
jonshouse
28/06/2013 18:59
jonshouse
28/06/2013 20:25
jonshouse
29/06/2013 10:02
jonshouse
29/06/2013 13:42
jonshouse
29/06/2013 21:33
jonshouse
25/06/2013 16:02
jonshouse
17/06/2013 23:58
Garry
23/06/2013 11:28
jonshouse
19/09/2013 10:51
jonshouse
27/09/2013 16:37
jonshouse
28/09/2013 23:08
jbrinkerhoff
30/10/2013 15:23
jonshouse
03/05/2013 01:19
jonshouse
03/05/2013 17:18
jonshouse
03/05/2013 14:08
jonshouse
03/05/2013 16:25
snowcrash
17/07/2013 01:23
jbrinkerhoff
17/07/2013 17:49
Jemmi
26/07/2013 11:59
Jemmi
29/07/2013 14:38
jonshouse
31/07/2013 19:47
jonshouse
31/07/2013 19:51
Jemmi
07/08/2013 11:27
jonshouse
10/08/2013 21:05
jbrinkerhoff
16/08/2013 10:44
jonshouse
27/08/2013 02:28
Jemmi
19/08/2013 18:10
jonshouse
27/08/2013 02:13
suomi35
11/07/2014 14:00
ShadowMan
04/11/2014 00:26
Daria
17/12/2014 18:13
Boelle
16/02/2015 11:18
Boelle
01/03/2015 15:13
Boelle
04/03/2015 16:08
Daria
05/03/2015 20:24
