I assume next job is upgrade from 1.02 software, and upgrade Emplode ?
Upgrade emplode before the player
Standard recommendation is to go to 1.03, do your bulk uploads there, and then if you feel adventurous upgrade to (currently) 2.0b11
"Mmmmmmmm...Wonder it it has the Dimmer mod done"
Not very likely, as the fix was just found out... Not that every player needs it, I have two MkIIa, none of which needs the dimmer fix.
/Michael
/Michael
