In reply to:
The Xaudio decoder is, as with almost all decoders, +- 0.5 bit (ie, the lowest bit of the output can differ from that of the frauhofer reference decoder).
The Xaudio decoder produces different output depending on platform. According to the compliance tests I have performed, the x86 version indeed passes the strictest accuracy test, but the ARM version passes only the limited accuracy test.
What do I mean?
Part 4 of ISO/IEC 11172 defines the compliance tests for MPEG audio and video. Section 2.6.3 defines the computational accuracy tests for audio decoders. It states, "To be called an ISO/IEC 11172-3 audio decoder, the decoder shall provide an output such that the rms level of the difference signal between the output of the decoder under test and the supplied reference output is less than 2^(-15)/sqrt(12) for the supplied sine sweep (20Hz-10kHz) with an amplitude of -20dB relative to full scale. In addition, the difference signal shall have a maximum absolute value of at most 2^(-14) relative to full-scale."
Then it says, "To be called a limited accuracy ISO/IEC 11172-3 audio decoder, the decoder shall provide an output for a provided test sequence such that the rms level of the difference signal between the output of the decoder under test and the supplied reference output is less than 2^(-11)/sqrt(12) for the supplied sine sweep (20Hz-10kHz) with an amplitude of -20dB relative to full scale."
The tests treat the decoder output as 24-bit signed fractional values in the range [-1, 1). In other words, the binary point is immediately after the sign bit. For the purposes of compliance testing, where only 16 bits of output are available, the remaining bits are set to zero. When I tested version 1.3.1 of the Xaudio decoder library under both x86 and ARM, here's what I found:
Xaudio 1.3.1, x86
RMS level = 8.602 x 10^-6 (under 8.810 x 10^-6; full accuracy compliant)
Max diff = 1.538 x 10^-5 (under 6.104 x 10^-5; full accuracy compliant)
Xaudio 1.3.1, ARM
RMS level = 2.065 x 10^-5 (over 8.810 x 10^-6 but under 1.410 x 10^-4; limited accuracy compliant)
Max diff = 6.580 x 10^-5 (over 6.104 x 10^-5)
As you can see, Xaudio's accuracy under ARM is worse than +- 0.5 bit; it's more like +- 2 bits, i.e., the 16-bit integer value can differ from the reference output by as much as 4 in either direction.
I'd be happy to share the Perl scripts I used to calculate these. The bitstreams and reference output used for compliance testing can be found here.
I'm curious; what decoder are you considering switching to?
-v
