Hi,
In reply to:
I installed my Mk2 in the car yesterday, and when you turn the ignition off, there is a second or so before the empeg clicks off.
I assume this does what the de-thump circuit does. (I never had a problem with it, as I use a second head unit to control the amps)
The ethernet is 10 meg only.
I'll pass on the other Q's (Although on my machine, a 4 gig clone took 11 hours)
Sounds like that'a stop the thump on my installation. I thought it might have been 10, as I remember somewhere that the empeg's StrongARM doesn't use DMA which I guess you'd need for 100?
Regards,
_________________________________________
John, (S/No 0114, 20G).
