It'll be corrected after the first 4000 units.
The corrections will be to fit power at pin 4 (same as mk1) and ground at pin 5.
DCD (cellphone mute) has been fitted to pin 1 and CTS (lights on sense) to pin 8.
Obviously, if you add power/ground to the connector in the same places, then when it is attached to the 4000+ batch connectors it'll still work just fine.
Hugo
