Hi,
It'll be corrected after the first 4000 units.
The corrections will be to fit power at pin 4 (same as mk1) and ground at pin 5.
DCD (cellphone mute) has been fitted to pin 1 and CTS (lights on sense) to pin 8.
Obviously, if you add power/ground to the connector in the same places, then when it is attached to the 4000+ batch connectors it'll still work just fine.
Sounds fair to me, Okay - I'll ammend my design details to reflect the two new cables on the D'Type: -
Pin 1 - Input - (DCD) Cellphone mute, Active Low, MK2 Only
Pin 2 - Input - RX
Pin 3 - Output - TX
Pin 4 - Power - (DTR) VBat +12V
Pin 5 - Ground - GND
Pin 8 - Input - (CTS) Lights Sence, Active High, MK2 Only
Next question, will the correction cable that you've offered to send come with the carry case, ISO cable and coloured panel that Rob said will be dispatched this week?
Regards,
_________________________________________
John, (MK1 114-20G, MK2 15-36G).
[color:yellow]_________________________________________John, (MK1 #114-20G, MK2 #15-36G).</font color=yellow>
