dang; just managed to kill my empeg; I'm re-flashing the consumer ver1 again:( something went wrong w/ the init file..
Here's the init that I used:
#!/bin/sh
PATH=./:/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin
PS1=empeg:\\w\\$
/bin/mount -n -o nocheck,rw /proc
/bin/mount -n -o nocheck,ro /dev/hda4 /drive0
/empeg/bin/player
inetd
...In theory, once it dumps out of the player, it should start inetd, right? only problem is that I can't get a prompt after I kill the player... Also, inetd never starts up... Ideas?
Also, it's worth noting the menu option for "quit" here:
(copied from Clemsonjeep)
In reply to:
) type rwm, then rw to mount the partitions read-write.
5) cd /empeg/var
6) echo "[Menu]" >> config.ini
7) echo "quit=1" >> config.ini
8) type rom, then ro, to mount the partitions read-only.
...proud to have owned one of the first Mark I units
