Greetings!
The boot log is the text that hyperterm will show when the empeg is first powered up. Basically, I just want to verify that it finds the second hard drive, that the data it sees is (basically) correct for a 20GB travelstar and any errors it sees when it tries to mount the partition.
Assuming that both drives work when they are hooked up alone as master, I am thinking it might be...
a) a connector on your cable is bad, so that the second drive is not seen at all during the boot
b) the drive is seen, but the partition mount never happens
c) the drive is seen, it tries to load the partition, but fails and gives an error message
d) both partitions mount properly, but the player software is confused by what it sees
Paul Grzelak
