I was perusing Phoenix Gold's website the other day and ran across this
amp. It's a 6 channe, 5x50 + 1x100 designed for in car theatre. What do the IASCA specs mean? If I'm reading this right, does it mean that if voltage drops to
12.5 volts then the amp is 18x5 + 36x1 or does it mean that their RMS numbers at 14.4 are BS or both? What voltage are amps typically quoted a...13.8v?
The footprint and the digital input seem to make it a good fit for an empeg with one of Stu's sound cards, no?
R5.1 Mobile Theater
R5.1MT
FRONT, REAR AND CENTER CHANNELS::
INTO 4 OHM STEREO AT 14.4 VDC (MAX POWER) . . .. . . . . . . . . . . . . . . . . . .100 X 5
INTO 4 OHM STEREO AT 14.4 VDC (RMS) . . . . . . . . . . . . . . . . . . . . . . . . . . . . .50 X 5
INTO 4 OHM STEREO AT 12.5 VDC (IASCA) . . . . . . . . . . . . . . . . . . . . . . . . . . .18 X 5
SUBWOOFER CHANNEL
INTO 4 OHM AT 14.4 VDC (MAX POWER) . . . . . . . . . . . . . . . . . . . . . . . . . . . . .200 X 1
INTO 4 OHM AT 14.4 VDC (RMS) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .100 X 1
INTO 4 OHM AT 12.5 VDC (IASCA) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .36 X 1
