3) If you want a true serial port a couple of companies make ones that fit in the modem slot on some late model Macs, the Griffin gPort is one example. You can also get PCI cards with serial ports on them that will work in Macs and PCs.
-Mike
EmpMenuX - ext3 filesystem - Empeg iTunes integration
