Tacking on an additional series of questions to the original topic...
The AirPort Admin software has no UI for checking your network's bandwidth usage, but that facility is something I rather need because our cable internet has a fixed monthly cap. It has logging, but it's what you'd expect from a network log, with all kinds of port and connection data just dumped as text down a page.
Using the Tomato firmware on my Linksys router I have it logging bandwidth statistics to my always-on media server via CIFS. Tomato has a UI to display bandwidth usage in a number of different ways, including by month, daily, weekly, by connection, etc.
At minimum I need a way to track the usage by month. I don't really know anything about SNMP, but I do know the Airport products have a check-box to enable it (on by default). It can also save syslogs to a remote client.
Will this data be suitable for analysis and construction of the usage reports I need? I've found some SNMP monitoring and graphing software on the net such as
PRTG Network Monitor and
PRTG Router Traffic GrapherThey both look like a little overkill, but at least they're free. As long as they don't take up too much CPU while running, I don't have a problem installing them on my Windows-based media system.
If anyone can provide any more information about monitoring this network connection, I'm all ears. Including any suggestions for simpler applications that may suit my needs.
I just found
Byte-o-Meter which looks a little less intimidating. Of course I still need to find out if these are gong to work at all.
