Originally Posted By: elperepat
Aliexpress seems to have quite a few available. But if you take in consideration the shipping time (at least for here in Canada), it might be as long as waiting for a Kingspec somewhere else.
I ended up getting two of the KingSpec 128's from Aliexpress, from your link. They arrived just fine and then sat around for a bit. But now I'm trying to use one, and having trouble putting it into one of my backup empegs. Anyone know what to do about this? I'm thinking this is something Mark Lord might know about.
Here's the situation:
I believe I did the correct things to use the bigdisk builder image on the drive, and it seemed to complete successfully. Connecting to the serial terminal after the application of the builder image was done, I see a bunch of numbers scrolling by which I think was the hard disk stress test. I powered it off then I applied a Hijack bigdisk 2.0 beta 13 image onto it. Then I applied Hijack v524.hijack.mk2.zImage onto the player. Everything seemed to work correctly.
But now that I'm trying to boot the player directly, and work with the drive, any time I have this drive plugged in (either by itself or in combination with another disk drive) it keeps saying "no primary hard disk" and "no secondary hard disk".
I don't know what the jumpers should be set to on these things, there's no dox. When trying to configure it as the solo drive in the player, I've tried configuring it with no jumpers, and with jumper on 1+2. When trying to configure it as the secondary drive in the player, I've tried configuring it with jumpers on 3+4. There's also some notes here which seem to indicate that "1+2" is "Cable Select" mode but I'm not so sure. I'd expect no jumpers to be cable select mode. Then again, different drives might be different.
Anyway, here's a boot log if this can help with diagnosis. Thanks in advance for any help or advice you can offer!
empeg-car bootstrap v1.02 20001106 ([email protected])
e000 v1.04
Copying kernel...
Calling linux kernel...
Uncompressing Linux...................................... done, booting the kernel.
Linux version 2.2.17-rmk5-np17-empeg55-hijack-v524 ([email protected]) (gcc version 2.95.3 20010315 (release)) #2 Fri Dec 15 08:52:50 EST 2017
Checking for extra DRAM:
c1000000: wrote ffffffff, read e28cc001
empeg-car player (hardware revision 9, serial number 40104196) 16MB DRAM
Command line: mem=16m
Memory: 14992k/16M available (1000k code, 20k reserved, 368k data, 4k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 67706d65 'empg'
Tuner: loopback=0, ID=-1
show_message("Hijack v524 by Mark Lord")
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0005280).
empeg RDS driver initialised
RAM disk driver initialized:  16 RAM disks of 4096K size
empeg single channel IDE
Probing primary interface...
ide_data_test: wrote 0x0000 read 0x0000
ide_data_test: wrote 0xffff read 0x0000
ide_data_test: wrote 0xaaaa read 0x0000
ide_data_test: wrote 0x5555 read 0x0000
hda: PA25-128, ATA DISK drive
ide_data_test: wrote 0x0000 read 0x044a
ide_data_test: wrote 0xffff read 0x3fff
ide_data_test: wrote 0xaaaa read 0x044a
ide_data_test: wrote 0x5555 read 0x3fff
hda: PA25-128, 121082MB w/1kB Cache, CHS=15435/255/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:28:10:64
Partition check:
empeg-pump v0.03 (19980601)
Mounting proc
Mounting first music partitiVFS: Can't find an ext2 filesystem on dev ide0(3,4).
on
Tried to mount /dev/hda4 as ext2 but got error 22
No primary hard disk
No secondary hard disk
Press 'q' now to go into development mode. You Have Zero Seconds To ComplyîStarting player
Timezone: Atlantic/South_Georgia
! tags.cpp          :  61:Failed to open tags (0xc0041002).
Prolux 4 empeg car - 2.1434 Jul 24 2002
q
Restored terminal settings
Player exited normally: 0
Switching to shell-player loop
Starting bash.
empeg:/empeg/bin# cd /
empeg:/# ls -al
total 25
drwxr-xr-x   15 502      220          1024 Jul 24  2002 .
drwxr-xr-x   15 502      220          1024 Jul 24  2002 ..
drwxr-xr-x    2 0        0            1024 Jul 24  2002 bin
drwxr-xr-x    2 0        0            1024 Jul  4  2000 dev
drwxr-xr-x    2 0        0            1024 Jul  6  1999 drive0
drwxr-xr-x    2 0        0            1024 Jun  2  1999 drive1
drwxr-xr-x    4 0        0            1024 Jul 24  2002 empeg
drwxr-xr-x    3 0        0            1024 Sep 15  1999 etc
drwxr-xr-x    2 0        0            1024 Feb  9  2000 lib
drwx------    2 0        0           12288 Jul 24  2002 lost+found
drwxr-xr-x    2 0        0            1024 Jun  2  1999 mnt
dr-xr-xr-x   19 0        0               0 Aug 31 23:54 proc
lrwxrwxrwx    1 0        0               3 Jul 24  2002 sbin -> bin
lrwxrwxrwx    1 0        0              10 Jul 24  2002 swapfile -> ./dev/hda6
drwxr-xr-x    2 0        0            1024 Apr 13  1999 tmp
drwxr-xr-x    4 0        0            1024 Feb  6  2000 usr
drwxr-xr-x    3 0        0            1024 Aug 28  1999 var
empeg:/# cd drive0
empeg:/drive0# ls -al
total 2
drwxr-xr-x    2 0        0            1024 Jul  6  1999 .
empeg:/drive0#
