We have had a winner!
The 1.8" Kingspec IDE/PATA drive I found on Amazon Canada: https://www.amazon.ca/gp/product/B0099395FA/
Builder (v6) worked without fuss, and I then installed the v3b11+Hijack .upgrade over that, again totally fuss-free.
The drive even has screw holes for mounting, two of which match the empeg's drive sled.
I suppose I might order a second one for here, while they're still available.
EDIT: Drive/firmware identification data below. One difference between this one
and the fake Yansen drive, is no mention of the "Security Mode feature set" on the genuine article (below).
Another difference is that the Yansen drives are native SATA (not PATA), but with a conversion chip onboard.
The SATA settings also show up in the drive identification data for those, but not for the genuine Kingspec.
Also, jumper settings are documented, and it WANTS the jumper in place for MASTER (opposite of the diagram we found earlier).
ATA device, with non-removable media
        Model Number:       KSD-PA18.6-128MS
        Serial Number:      986110xxxxxx
        Firmware Revision:  20131216
Standards:
        Supported: 9 8 7 6 5
        Likely used: 9
Configuration:
        Logical         max     current
        cylinders       16383   16383
        heads           15      15
        sectors/track   63      63
        CHS current addressable sectors:    15481935
        LBA    user addressable sectors:   247975936
        LBA48  user addressable sectors:   247975936
        Logical/Physical Sector size:           512 bytes
        device size with M = 1024*1024:      121082 MBytes
        device size with M = 1000*1000:      126963 MBytes (126 GB)
        cache/buffer size  = 1 KBytes (type=DualPort)
        Nominal Media Rotation Rate: Solid State Device
Capabilities:
        LBA, IORDY(can be disabled)
        Standby timer values: spec'd by Vendor, no device specific minimum
        R/W multiple sector transfer: Max = 1   Current = 1
        DMA: mdma0 mdma1 mdma2 udma0 udma1 udma2 udma3 udma4 udma5 *udma6
             Cycle time: min=120ns recommended=120ns
        PIO: pio0 pio1 pio2 pio3 pio4
             Cycle time: no flow control=120ns  IORDY flow control=120ns
Commands/features:
        Enabled Supported:
           *    SMART feature set
           *    Power Management feature set
                Write cache
           *    WRITE_BUFFER command
           *    READ_BUFFER command
           *    NOP cmd
           *    48-bit Address feature set
                Mandatory FLUSH_CACHE
                FLUSH_CACHE_EXT
HW reset results:
        CBLID- above Vih
        Device num = 0
Checksum: correct
Edited by mlord (16/05/2019 15:52)
