The Mk2 should be easier to install: as default, the outputs are not floating ground (they can be made floating ground if required though, the circuitry is similar). This means that as default, it's about as easy to install as any other stereo: the ISO power connector means that for most cars, hooking up power, lights sense, etc is a simple plug-in operation.
Hugo
