Got it. I will get you something tonight. I am not sure if the datum on my GPS (Garmin eTrex) can be adjusted. I will have to check that.
I just read that all Garmin receivers default to WGS84 which is very close to NAD83 and the difference is 2m maximum, so it should be no problem.
If you get something grabbed, you can send it to me via email (after removing the nospam from the address).
Kim
