The idea is we'll default to 4800, and then emplode will try pinging at 115200 & if the empeg doesn't respond, will switch to 4800 and send a "switch baud rate to 115200" command.
This way, if you make a new gadget for the serial, it can start at a low rate and step up as necessary.
This is a slightly far-off change though, as it requires the gadget to talk the error-corrected serial protocol that emplode uses. I suspect a line in the ini file on the empeg will appear first.
Hugo
