Hi Henno & Rob,
In reply to:
The bug to which you refer has nothing to do with setting the volume - it's a problem with missing key-up commands from the front panel buttons. This only applies to an internal empeg interface - John's project uses the serial port and cannot possibly be affected by this issue.
That's right. No problem using the stick controller, except when it's in repeat mode and the rate ramps up, the empeg can skip commands. This isn't a problem that it doesn't keep up as the rate is quite high by then and you'd hardly notice it.
Regards,
_________________________________________
John, (S/No 0114, 20G).
