try powering it from the 12v permanent feed and/or the 12v ignition feed instead of powering it from the amp remote line
Can't come from permanent. It's a stealth box with no Off switch. I suppose it could come from ignition switched, but I'd then have to fuse it.
You could have it come for permanent through a relay activated by the amp remote line. Maybe.
