MK2a
The signal lines on the serial connector are driven from the GPIO lines of the StrongArm, via an RS-232 driver (a
Maxim MAX3241 chip), a thick-film resistor array (a
Bourns 4420P chip) and some other minor components. Some of the lines perform other roles when the player is in DC mode (typically, when in a car).
Serial GPIO SA Other Uses
1 DCD [in] 27 51 Telephone Mute
2 RD [in] - -
3 TD [out] - -
4 DTR [out] 23 55 debug LED?, MK2 SIR endec speed sel 1
5 GND
6 DSR [in] 21 59
7 RTS [out] 24 54 MK2 SIR endec speed sel 2
8 CTS [in] 22 56 Headlight Sense
9 GND*
Notes
DTR is sometimes called DTS
DCD is normally called CD
SA is the pin on the StrongArm upon which the signal is present
*As far as I can tell, pin 9 (normally ring indicator - RI) is grounded.
I couldn't work out where pins 6 and 15 of the 4420P go, nor pins 8 and 15 of MAX3241. Pins 1 and 10 on one side of the 4420P and pins 11 and 20 on the other side seem to be connected to their respective grounds.
I am unclear on whether pins 2 and 3 should be swapped,
see this thread.
