Also the selection of speed limits are oddly restricted, for example you there is no option between 300kb and 1mb !?
You can enter a custom value of any number but I agree it's not the most flexible. I'm still trying to figure out a way to let it run full blast all the time and be throttled at my firewall/router.
Ah yes, hadn't spotted "Other" hidden down there at the bottom.
I want my bandwidth control in the software. I've also got bittorrent uploading data 24/7, controlling the two sharing bandwidth at the router would be much harder than having a scheduling option in the software (as uTorrent already has).
I really need them to fix the WAN/LAN detection. That is a completely brain dead design choice they've made there.
I could really do with the option to spot when a machine has moved from its home LAN too, so that you can ramp back the bandwidth usage (or disable it completely) when you take you laptop elsewhere.
