Yeah.
Ideally, any directory called "var" is for "Var-iable" data, stuff that is written/rewritten fairly often. Program files and other semi-permanent entities are generally better off elsewhere -- less danger of losing them in the even of a filesystem update error/crash when writing the "var" directories.
But then, this IS linux, so you're highly unlikely to ever lose data from a filesystem crash..
