Or some kind of an internal reset. If only I knew how.
Disconnect the battery and any internal battery backup and let it sit for a bit? Won't do you any good for settings in flash, but if it is storing anything in volatile memory you should be able to clear it.
-Mike
EmpMenuX - ext3 filesystem - Empeg iTunes integration
