Ah ha! Thank you indeed.
empeg:/drive0/var# ./hdparm.bin -I /dev/hda
/dev/hda:
ATA device, with non-removable media
        Model Number:       TS32GSSD25-M
        Serial Number:      00238605014A
        Firmware Revision:  V0826
Standards:
        Used: ATA/ATAPI-7 T13 1532D revision 4a
        Supported: 8 7 6 5 & some of 8
Configuration:
        Logical         max     current
        cylinders       16383   16383
        heads           16      16
        sectors/track   63      63
        CHS current addressable sectors:   16514064
        LBA    user addressable sectors:   62586880
        device size with M = 1024*1024:       30560 MBytes
        device size with M = 1000*1000:       32044 MBytes (32 GB)
Capabilities:
        LBA, IORDY(can be disabled)
        Standby timer values: spec'd by Standard, no device specific minimum
        R/W multiple sector transfer: Max = 1   Current = ?
        Recommended acoustic management value: 128, current value: 254
        DMA: mdma0 mdma1 mdma2 udma0 udma1 udma2 udma3 udma4 *udma5
             Cycle time: min=120ns recommended=120ns
        PIO: pio0 pio1 pio2 pio3 pio4
             Cycle time: no flow control=120ns  IORDY flow control=120ns
Commands/features:
        Enabled Supported:
           *    SMART feature set
                Security Mode feature set
           *    Power Management feature set
                Write cache
                Look-ahead
           *    Mandatory FLUSH_CACHE
           *    SATA-I signaling speed (1.5Gb/s)
           *    SATA-II signaling speed (3.0Gb/s)
Security:
        Master password revision code = 65534
                supported
        not     enabled
        not     locked
        not     frozen
        not     expired: security count
        not     supported: enhanced erase
        2min for SECURITY ERASE UNIT. 2min for ENHANCED SECURITY ERASE UNIT.
Integrity word not set (found 0x0000, expected 0xa8a5)
Steve
