Do you happen to remember exactly which screen this is on?
Under Firewall->Advanced there is a a setting called "TCP Connection Inactivity Timeout - Default Connection Timeout (minutes):" This setting does not set the Timeout for everything on the box. It simply specifies what the default timeout will be for each new Access Rule that's created in the firewall. Each Access Rule has its own timeout.
Select the rule that reads "LAN * Any Allow" and hit configure. Go to the Advanced tab and you will find the setting "TCP Connection Inactivity Timeout (minutes):" Set it to whatever you like.
The default for the box is 5 minutes on every rule. If you want a specific service to have a higher timeout than the others, just create an Allow rule for that service and specify it there.
You accomplish bandwidth management in the same way.
