My guess is that the Windows firewall may be interfering with automatic discovery.
I don't think I've needed to adjust Windows Firewall in a long time. Only real old versions of Windows Firewall were ever an issue.
Shouldn't it "just work"?
Doug, you're right, it should Just Work based on the settings you were just showing. Double check the "Options" button in the "Select empeg-car" screen in Emplode, like Tom said. Make sure you didn't change the settings in such a way as to prevent the player from being discovered.
Another thing to check: Emplode can't talk to the player if the player thinks it's in "Car" or "DC" mode. Make sure the player is in "Home" or "AC" mode before trying to connect with Emplode.
