I guess it depends on how often you're making that system image.
But RAID 1 would basically give you zero downtime, as your other working drive would just...keep working. Then at your leisure you could pop in another SSD when you're ready to rebuild the array (which I assume would take very little time with an SSD array).
If both drives bit the dust, you'd have that clone you made.
