Glovebox has 6 or 8 screws from memory.
Two in the air vents above glovebox you might have to remove vents,
Two on the top lip of glove box (maybe last one didn't have it this one does)
Two either side of the actual glovebox under the door when closed
Two right under the glovebox
It should then pull towards you and drop down giving lots of room and hopefully access to the Din slot,
What i have done is cut a hole in the glovebox and lead into it a docked ethernet cable, serial cable, tuner cable, and aux in cable.
P.Allison fixer of big engines Mk2+Mk2a signed by God / Hacked by the Lord Aberdeen Scotland
