Yea, I can telnet in and kill telnet and then reset power to get telnet back up after a resync. Emplode fails when checking media, and none of the changes to config.ini are ever applied when I have telnetd running off of /drive0/bin. I'm sure I could put it in /bin and not have a problem, but the point of putting it on /drive0 is to prevent the need of doing anything after an upgrade. It seems as if applications should be run from /programs0, and data should be located on /drive0.
