Um, if you did id3lib installation then it should have put them in /usr/local/lib by default. It's LD_LIBRARY_PATH. Add /usr/local/lib to that and see if that helps you out.
Edit: I'm truly earning my forum rank tonight...
Edited by yn0t_ (09/02/2003 23:11)
