I'm going to be using 4 gauge wire How many amps are you figuring to pull, here, Grymm?
One of my pet peeves
is this idea people have that amplifiers somehow work better when they have cabling eight or ten times bigger than required. Look in the IASCA book and there's a chart showing minimum required wire gages for given amp sizes and cable runs. At my last competition I lost points because I only had 8 gage wire going to my amps -- separate wiring runs to each amp, one of them 50 watts, the other one 100. I could have run 18 gage wire and been perfectly all right.
Anyway, don't fall into the trap of thinking you have to run welding cable to your amps. Check it out, and you may save yourself a lot of trouble.
