272 is Unattached Items, but it's not that jEmplode has added it, it's that jEmplode has REMOVED it.
Hence JEmplode's desire to delete everything from the Central when you press synch? Everything on the Central is an unattached item, playlists aren't used by default unless you specifically create them.
