Rex,
After much experimentation and only reloading the player once I have gotten to where I get this on the boot message.
: command not foundel memory: 4k init/etc/preinit.d/init_empgps.sh:
: command not found_empgps.sh:
': not a valid identifiers.sh: export: `
mount: you must specify the filesystem type
Usage: mount [-hV]
mount -a [-nfFrsvw] [-t vfstypes]
mount [-nfrsvw] [-o options] special | node
mount [-nfrsvw] [-t vfstype] [-o options] special node
A special device can be indicated by -L label or -U uuid .
'etc/preinit.d/init_empgps.sh: line 24: syntax error near unexpected token `
'etc/preinit.d/init_empgps.sh: line 24: `fi
empeg init 0.8
My script is just a copy of the content of your message. I have made empgps and the script executable and have removed all other scripts from /preinit.d. I am sure that there is some obvious Linux knowledge I am missing but don't know what it is yet! Any clues would be great.
Thanks,
Lynn
