That looks fine.
By reboot, do you mean power cycle (or reboot from hijack) or 'quit' the player? If the latter then you may have empgps and the player in non -s- mode running at the same time.
If you are rebooting I can't see any potential for interaction between the apps. The disk is even mounted read-only.
Early versions of the empgps/picker script did not support the shell over serial. The current one does. (It's on the empgps page.) If you have an early one, use hijack's ftp to replace the picker script.
Rex.
