In reply to:
1) jemplode allows you to exit while a sync is happening. really bad, since the bar is invisible to an unknowing user. did that accidentally.
Hmm .. whoops .. that's supposed to ask you if you are sure (if there are pending transfers).
In reply to:
you try to add some files (about 60 albums), not sync and revert changes
I'll check this out ...
In reply to:
suggest to default starting the right pane in the "Playlists" folder.
shouldn't be a big deal -- i'll try it out ...
In reply to:
upload the 60 albums again, then before syncing, deleted everything with "remove completely"....
You get the Evil Tester Award ... I'll check this out also.
In reply to:
using the cancel button in the sync doesnt work. it keeps on going. you need to highlight all the items and rightclick, then cancel for it to actually happen.
Hmm .. OK.
In reply to:
WMA files arent supported.
It's supposed to be -- Though I don't actually HAVE any WMA's, so it doesn't get tested. You're not trying to upload DRM'd WMA's, right? That will definitely fail. What errors are you getting? Is this the UTF16-LE one?
