Originally Posted By: crazyplums
much equipment i used to repair had be taken apart in a certain order or you'd end up with all sorts of trouble
I think more people get into trouble putting Empegs back together, than they do taking them apart. You need to be super-careful that you put the ribbon cables back on correctly; being off-by-one on the drive cable means it won't boot until you fix it, but being off-by-one on the front-panel cable will blow a fuse, necessitating a surface-mount repair job.
