So.. for getting track data from the empeg:
Two scenarios:
(1) Arduino manages BT module: Hijack needs to intercept serial input, and respond to requests for track info, otherwise leaving the serial port as-was (passing everything else to the player).
(2) Empeg (Hijack) manages BT module: Hijack can safely dedicate the serial port to only the BT module; no need to worry about player commands or anything other than BT passing through.
EDIT: Or perhaps somewhat simpler for number (1): Hijack could just periodically broadcast track info over the serial port, unsolicited. The Arduino could listen for this and cache it for later response if/when queried by the head unit.
Does the Arduino sketch currently wait-for/read anything else on the serial port?
Edited by mlord (24/10/2017 19:37)
