Commands imply means, settings imply results. IE, if you configure something to shift the soundstage 30 cm to the left, you don't care how it actually does the shifting, you are only interested in the end result. However, if you are performing a command, you would have it delay the right channel 3msec or something.. The context is important in this situation, which is why I think some people are being confused..
