I've completed my CF upgrade using the
http://www.psism.com/adcf.htm#2-slot adaptor and the same 16GB CF that Mark found.
Some items to note:
- The first connector on the stock cable can't be used with this adapter.
- The 3.5" connector isn't useful. I'll be desoldering all the pins soon.
- I wound up mounting this at right angles. See pics. This has the advantage of making it easy to R&R the CF card or to add a second one when needed, without having to do more than pull the cover. Also the cable folds well without blocking the vents.
[img]http://empegbbs.com/files/301875-cf.JPG/img]
Edited by gbeer (24/07/2007 01:15)
