But later, I completely got rid of the plastic casing so that I could stealth mount it and position the antenna wherever I wanted. I wrapped the whole thing in electrical tape and soldered a proper serial cable to the PCB instead of the loose pins.
You don't have to go this far if you still want to use it with the palm3.
