I thought that I tested it for 100 feet, not meters. Patrick Arnold did the design - I was just a paper pusher on this project.
I will share a little story Patrick shared with me prior to the design. He created a similar design to extend EIDE drives for long distances. He mentioned that his testing consisted of using a very old drill with a metal housing. You know, the kind where you can see sparks coming off of the brushes. He wrapped the EIDE cable around the drill and ran the drill during the test trying to introduce a great deal of interference - the design worked perfectly. At that point, I knew I was working with the right engineer for the project.
Be sure to spec zero halogen cable for those 737 installations.
