Sure, you could run cable from your computer room to the next door neighbor's garage, but that does nothing without a speaker run of the same distance.
Piece-o-cake: Stu also makes/installs SPDIF/Optical outputs for the empeg, so we just need to do one of:
  • string an optical cable along with the ribbon cable, or
  • run the SPDIF signal in the existing ribbon cable, making use of the spare transceivers in the MAX* chips (mm.. gotta double check those), and using a (former) GND wire in the cable for the transmission.
Edited by mlord (28/03/2007 12:13)
