I believe about the smallest enclosure you could get away with with the display stacked on top of the receiver is 6.3" x 2" x 2".
Actually, 1 3/8" deep is possible, by having the receiver board mounted with component side facing the display board.
This puts the cable feed onto the top of the display though. To have it feed from the bottom (preferred), the middle ("spare") DB9 connector needs to be removed from the receiver board (or just not soldered in place to begin with).
Mark
Well, a bit of 2"x2" a spare lens and a spare bezel made a good prototype showing where it has to go:
http://www.dgreaves.com/bins/Cars/xkr/empeg_install/imagelist.html
So saving a little space would be good unless we install into the vents.
