Do I simply(!) dismantle my Empeg, unscrew/remove the display board, plug in the transmitter, attach the display to the receiver, route the ribbon cable, crimp the ribbon cable with a pair of pliers (!) and then plug it together for instant remote goodness?
More or less, except that the ribbon cable arrives with connectors already crimped in place.
And you'll need to work out a mounting system / enclosure for the remote display -- it needs a slim box of some sort, or perhaps could be inset into the dashboard.
The stock empeg bezel & lenses would be used on the display, same as now. Except there's no carry handle on the remote display, so the factory bezel might look a bit odd.
Edited by mlord (29/03/2007 14:15)
