Get it at the usual place.
Changes for v2.00:
  • The Windows batch file was broken in v2.00, and has been fixed, and hopefully fixed correctly. If you had install problems, try again with this one.
  • Install scripts now support an "upgrade" where the existing XML file is kept intact, and config.ini is left unchanged.
  • The postinstall script has been fixed to add some important config.ini changes, without which emphatic won't function properly.
  • Thanks to some improvements to the Hijack user APIs, emphatic now provides the option to bring itself to the foreground on player startup. This requires Hijack v408 or later. The new behavior is now the default, so if you wish to turn it off, set the auto_foreground setting in the XML file to "false."
  • New track attribute, "bpm", which is the beats per minute as calculated by the player. Shown in the Track Details screen in the default XML file
Enjoy this release, and please post here if you have any problems, or any general comments about this release. Please keep feature requests in the other relevant thread in this forum.
