Version 2.03 is now available, same bat time, same bat channel.
New stuff:
  • The Unix script is fixed this time. For real. No, really, it is.
  • The postinstall script now adds car_rate=115200 to the [serial] block of config.ini (creating that block if necessary.) This is necessary to avoid serious slowdowns and lockups when using emphatic in DC power mode.
  • The auto_foreground setting now not only brings emphatic to the foreground on startup, but also when waking up from standby. This may not work well in car mode, something I'm investigating.
  • Fixed a bug which would cause emphatic to crash in certain situations
  • Fixed a bug where sending of IR codes for info change and visuals wouldn't work properly in DC mode
