I wonder if the problem has anything to do with lrctool not parsing Linux style end-of-line codes properly? Just a random idea.
FWIW, I have the same issue with time stamped blank lines and horizontal lyric mode. I used XP and the SYLT plugin, so it's not a Linux issue. I also tried using a space instead of a blank line in an attempt to fool it into scrolling the lyrics quicker. No dice there, either.
Tony, is this something that might be fixed in the next version?
No longer a stranger, finally a full-fledged member! \:D
