Been a way from the BBs for a while, I saw this great program and I decided to installed it on my Empeg II player and it seems to be having a problem.... The symptoms are as follows..
The player starts up and does the initiazation and it get to the point where it loads Emphatic and the screen (Player's Display) just goes blank and the power LED goes out.... Sometime I can get Emphatic to work after several reboots but then it would just lock up...Using my serial port I captured this:
It seems to me that I'm running out of swap space and causing the program to crash... the file sizes are okay in /usr/local/bin so the install went well. I'm using Hijack v4.13 and the Developer's verion 2.0.
Serial Output:
empeg-car bootstrap v1.00 20000601 ([email protected])
e000 v1.04
Copying kernel...
Calling linux kernel...
l.
Linux version 2.2.17-rmk5-np17-empeg52-hijack-v413 ([email protected]) (gcc version
2.95.3 20010315 (release)) #2 Tue Aug 17 18:05:30 EDT 2004
Checking for extra DRAM:
c0c00000: wrote ffffffff, read e91ba9f0
empeg-car player (hardware revision 7, serial number 80000457) 12MB DRAM
Command line: mem=12m
Memory: 10952k/12M available (984k code, 20k reserved, 328k data, 4k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 67706d65 'empg'
Tuner: loopback=0, ID=-1
Scheduling custom logo.
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0004f80).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
hdb: IC25T060ATCS05-0, ATA DISK drive
hda: IC25T060ATCS05-0, ATA DISK drive
hda: IC25T060ATCS05-0, 57231MB w/1768kB Cache, CHS=7296/255/63
hdb: IC25T060ATCS05-0, 57231MB w/1768kB Cache, CHS=7296/255/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:10:01:c
9
Partition check:
empeg-pump v0.03 (19980601)
Mounting proc
qMounting second music partition
Starting player
Timezone: Atlantic/South_Georgia
qHijack: intercepting config.ini
qopening display...
/bin/sh: DC: command not found
hijack: removed menu entry: "Hard Disk Detection"
hijack: removed menu entry: "Serial Port Assignment"
khttpd: listening on port 80
kftpd: listening on port 21
emphatic v2.04 (built Aug 17 2004 21:05:49) running as pid 12
q player.cpp : 385:empeg-car 2.00 2003/04/01.
q
q
e000 v1.04
Copying kernel...
l.
empeg state support initialised 0089/88c1 (save to d0005000).
9
Partition check:
Mounting proc
q
qRemounting first music partition read-only
SStarting bash.
q
q
qempeg:/empeg/bin# q
bash: q: command not found
empeg:/empeg/bin# q
empeg:/empeg/bin# q
empeg:/empeg/bin#
empeg:/empeg/bin#
empeg:/empeg/bin#
empeg:/empeg/bin#
empeg:/empeg/bin#
empeg:/empeg/bin# df
df: cannot read table of mounted filesystems: No such file or directory
empeg:/empeg/bin# cd /usr/local
empeg:/usr/local# ls
bin
empeg:/usr/local# cd bin
empeg:/usr/local/bin# ls -alF
total 485
drwxr-xr-x 2 0 0 1024 Dec 29 03:08 ./
drwxr-xr-x 3 0 0 1024 Dec 29 03:08 ../
-rw-r--r-- 1 0 0 13032 Dec 29 03:08 13pixel.bf
-rwxr-xr-x 1 0 0 392924 Dec 29 03:08 emphatic*
-rw-r--r-- 1 0 0 22618 Dec 29 03:08 emphatic.dtd
-rw-r--r-- 1 0 0 15552 Dec 29 03:08 emphatic.xml
-rwxr-xr-x 1 0 0 22883 Dec 29 03:08 irattach*
-rw-r--r-- 1 0 0 15626 Dec 29 03:08 large.bf
e000 v1.04
Copying kernel...
l.
empeg state support initialised 0089/88c1 (save to d0005080).
9
Partition check:
Press Ctrl-A to enter pump...nted root (ext2 filesystem) readonly.
Mounting proc
Starting player
opening display...
Vcb: 0x4054d000
VM: do_try_to_free_pages failed for kswapd...
VM: do_try_to_free_pages failed for player...
VM: do_try_to_free_pages failed for emphatic...
VM: killing process emphatic
buffermem : 483328
page_cache_size : 305
nr_free_pages : 24
num_physpages : 3072
buffermem : 483328
nr_free_pages : 23
buffermem : 483328
nr_free_pages : 24
spindown_chunk_cache_runner.cpp: 294:Filling up space (2)
spindown_chunk_cache_runner.cpp: 294:Filling up space (6)
Blk Infiniti I-30, 1 OVR 0 MkII Serial # 080000457, 120gigs +2000 Music Cd's [Listing avail]
