Originally Posted By: Cris
I assume the 2TB limit is the same in OS X ???
Depends. If you are running any of the past 4 major versions, 2TB won't be a problem when using HFS+. Other file systems will depend on the limits there (NTFS, FAT32, SMB, etc). For an Intel mac, the MBR limit still applies, so make sure to partition it using GPT and not MBR. I believe Disk Utility will default to GPT in Leopard.
