Hi,
Yes, I followed Mark's new instructions in the FAQ.
I installed hijack 488 prior to any install as the instructions indicate. Then the Big Disk Builder, then the player hijack that was recommended.
I thought the player software was the car2.v2.01_hijack.
I have tried this on 2 different known good Rio's and 2 different disk drive cables. I have completed the above install and tried v2b13 Hijack as well.
I started with a new 250 GB drive.
Here is the result of the above requests:
<CTRL C>
Restored terminal settings
No primary hard disk
No secondary hard disk
Abnormal player termination
Player received SIGINT, user interruption
Switching to shell-player loop
Starting bash.
empeg:/empeg/bin# cat /proc/partitions
major minor #blocks name
3 0 134217727 hda
3 1 1 hda1
3 2 40162 hda2
3 3 24097 hda3
3 4 134110620 hda4
3 5 24034 hda5
3 6 16033 hda6
empeg:/empeg/bin#
empeg:/empeg/bin# fdisk -l
Usage: fdisk [-l] [-b SSZ] [-u] device
E.g.: fdisk /dev/hda (for the first IDE disk)
or: fdisk /dev/sdc (for the third SCSI disk)
or: fdisk /dev/eda (for the first PS/2 ESDI drive)
or: fdisk /dev/rd/c0d0 or: fdisk /dev/ida/c0d0 (for RAID devices)
I assume this is what you really wanted.
empeg:/empeg/bin# fdisk /dev/hda -l
Disk /dev/hda: 255 heads, 63 sectors, 16709 cylinders
Units = cylinders of 16065 * 512 bytes
Device Boot Start End Blocks Id System
/dev/hda1 1 5 40131 5 Extended
/dev/hda2 6 10 40162+ 83 Linux
/dev/hda3 11 13 24097+ 10 OPUS
/dev/hda4 14 16709 134110620 83 Linux
/dev/hda5 1 3 24034+ 83 Linux
/dev/hda6 4 5 16033+ 82 Linux swap
empeg:/empeg/bin#
These were the same partition assignments that I got when I manually partitioned the drive too.
By the way, if anyone else is trying to upgrade to these drives, they seem to be in short supply.
Thanks for the help,
